The current-while timer value returned NULL. Could not allocate memory
Check if the receiver machine parameters are initialized correctly for the LACP module. Check for the switch memory statistics. show memory show memory process lacp
Critical
Failed to create create LACP current while timer. port: %portId%
| Name | Type |
| portId | String |
